720p or 1080
Discussion in 'Xbox Forums' started by kevmiller, Sep 20, 2007.
  1. kevmiller
    kevmiller
    Sep 19, 2007
    540
    Leigh
    +6
    hi guys today i have upgraded to the elite however i am no expert and not very technical however which one do you guys have your xbox set at is it 720 or 1080 my tv is a lg 42" plasma hd ready and it 1 year old
  2. daymouse
    daymouse
    Feb 12, 2007
    6,226
    +1,055
    1080p all the way mate
    basically the rule is the higher the number the better. its talking about the amount of pixels so 1080 pixels is better than 720 and 720 is better than 480
  3. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    There wont be much in it, your panel is probably 768 pixels so there will be some scaling either way. Depends if your TV's better at upscaling or downscaling, just try them both and see what you prefer. When I had a 768 panel 1080i was slightly better, but that was a different make to yours (Toshiba).
  4. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    Whilst that's kind of true its pretty bad advice. FATFINGERS73 explained a little better.
  5. SpaceGhost
    SpaceGhost
    Dec 4, 2006
    447
    Sheffield
    +33
    I have a 42" LG Plasma (42PC1D), with a native resolution of 1024x768. I personally use the VGA cable as I have a premium. This allows me to select the exact resolution of the TV, 1024x768 rather than having to select 720p or 1080i.
    I'm presuming that with HDMI on the 360 you get the same options that you get with the component cable? (720p/1080i/1080p)
    As has been mentioned, just go for the one that looks best on your TV. I have another HDMI device (BT Vision) and personally I select 720p on that because it's progressive scan.
  6. JamesCTR
    JamesCTR
    Aug 10, 2007
    153
    Warminster, Wiltshire
    +12
    If your TV is 1 year old, i doubt its going to be FULL HD. So i would choose the 720p instead of the 1080i. But its down to your eyes at the end of the day, its down to what YOU think looks better ! :D
