720p on the Quali-TV QS1080IR ??
Discussion in 'General TV Discussions Forum' started by Mich8, Nov 5, 2004.
  1. Mich8
    Mich8
    Hello everyone,
    I can only select 1080i output in the menu of the QS1080IR. Is it not possible to activate 720p?
    It's one thing if the receiver would output the same as the input, i.e. 720p signal --> 720p output. Does it do that?
    What I really want to do however is a bit different. I want to have a 1080i signal (such as HD1 & Astra HD) --> 720p on the output. Is this possible?
    PS. On another note, I can't seem to get RGB on the SCART connectors. Only composite.. this also seems strange.
    PS. I just found the funniest smiley I've seen so far.. This is me watching HDTV.. :zonked:
  2. debris
    debris
    What version of firmware does your rec says?
  3. GMeijer
    GMeijer
    Hi Mich,
    Press the V-Format button on the RCU to change the output format. Press once shows current format, press again selects the next format. The SCART only supports CVBS, not RGB. RGB is available from the RGBHV conector.
    Gerard.
