720p and 1080i resolutions for TVdrive.
Discussion in 'Cable TV & Virgin Media TV' started by bboy-mass, Mar 19, 2006.
  1. bboy-mass
    bboy-mass
    Dec 31, 2002
    338
    Birmingham
    +12
    Hello,
    I have a PD7200 plasma (Alas) pannel 1024x1024.
    So, what is the best resolution for me to use via VGA?
    My friend has a component to VGA box, and Im goign to see if this fixes the TVdrive problem. I have lots of control over the picture if I use VGA, so its going to be interesting to see what happens.
    Please advise on what res i need to set for 720p and 1080i
    Cheers,
    Bboy
    Birmingham
  2. cerebros
    cerebros
    Dec 27, 2002
    1,366
    48
    Leicester
    +43
    Why not try both and see what looks best to you? Would seen to be the best solution...
  3. bboy-mass
    bboy-mass
    Dec 31, 2002
    338
    Birmingham
    +12
    Yes, but using vga gives me a list of resolutions:eek:
    I need to know which ones represent 720p?
    is it 1024x720 or 1280x760 ?????
    Regards
    Nigel
  4. cerebros
    cerebros
    Dec 27, 2002
    1,366
    48
    Leicester
    +43
    Well if it doesn't tell you in the manual just try the different options until you find which one looks best. Might be quicker than waiting for someone with the same panel to reply... :)
  5. bboy-mass
    bboy-mass
    Dec 31, 2002
    338
    Birmingham
    +12
    I'll wait.
    Cyber will know.
    Thanks,
  6. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    897
    Lancing, West Sussex
    +82
    My understanding is that 1080i will look better on an Alis panel. The Alis technology is inherently interlaced, and futhermore, 1024 lines is a lot closer to 1080 than 720 ! I had an Alis panel before, and 1080i looked much better.
  7. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    Yep - ALiS panels crop 1080i to 1024i - effectively dropping 28 lines top and bottom - rather than scaling.
    As they are effectively an interlaced display, then they should do a good job with 1080i material, if it remains 1080i through broadcast and distribution - i.e. material shot 1080/50i, compressed 1080/50i, received and decompressed 1080/50i and output 1080/50i.
    However, if the material has been shot 720/50p, and broadcast/decompressed/received in 720/50p - then the quality of the 720/50p conversion in the set top box in 1080/50i output mode compared to the quality of the 720/50p to 1024/50i conversion in the ALiS display will dictate which is better.
    You may not be able to see much difference.
