720p 1080i switching (hardware/Sky)
Discussion in 'General TV Discussions Forum' started by wilno, Aug 19, 2005.
  1. wilno
    wilno
    Feb 14, 2005
    I currently own a sharp xvz2000 PJ (720p/native) which I have hooked up to:
    Sky+ and my home computer (using Theatertek)
    Sky via component and the PC via a really long DVI cable (which works flawlessly by the way, so never be put off) :cool:
    At the present I get my HDTV stuff from (somewhere else) but with Sky finally getting round to it maybe that will change. ;)
    To view the 1080i files I find the best method is to reset the PC from 1600x1200 to 1280x720 and let the PC do the scalling to the PJ. Otherwise (say using VLC) the PJ downscales from 1080 to 540p then upscales to 720 (p?).
    Both look great don't get me wrong, but the scalling from the PC Is better.
    Two Questions
    Will Sky offer this scalling? - American hardware I belive has this switching ability :confused:
    Will I be able/ is it going to be possible to feed Sky through a Home PC to achive a similar result if not?
    Thanks (hope some of that made sense)!
    ATB
    Wilno - not to be confused with my brother Wino :devil:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,765
    The Borders
    +3,088
    Hello Wilno
    I believe SKY will simply offer the option for each channel broadcaster to transmit 1280x720P or 1920x1080i and whatever format they chose is the one the box will output - if you want to convert 1080i content to 720P ahead of your Display device you will require a Video Processor that can undertake that conversion.
    Best regards
    Joe
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,371
    +820
    You may be right - however if the Sky boxes behave as US DSat boxes do you may also find that you can run your box at a fixed output resolution (say 1080i or 720p) and have the receiver scale. Given that the chipsets for UK HD boxes are likely to be closely related to those used in the US (DirecTV in the US is going MPEG4 as well) it may be they offer the same facilities. In the US it is more common to find 1080i/480p/480i only displays - with no 720p capabilities, so I wouldn't be surprised.
    Don't forget the box has 3 resolutions to cope with - 576/50i, 1080/50i and 720/50p - as it will be standard def capable as well.
    If the box can run at a fixed resolution output there are major ergonomic advantages - as channel surfing between channels of differing formats may be quicker if your display doesn't have to keep altering to a different input format (probably accompanied by lovely on-screen graphics)
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    I certainly hope so, as my screen only takes 1080i.
    If they could guarantee HD Ready sets only, then they could switch the outputs (and save on some scaling hardware), but they have to deal with normal TVs (so at least a basic scaler is needed) and component HD.
    I want to tell it I have a 1080i only set, and therefore I only want 1080i out of it.
    BTW what will happen with SD content? my screen doesn't take 480 or 576i, so would the box upscale SD to 1080i as well? (me slowly realising I'm most likely stuffed)
  5. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,371
    +820
    I suspect the SD output on Sky boxes will be independent of the HD output (so that SD is present irrespective of the HD output, to allow VCRs and DVD recorders to record shows still) - so any downconversion scaler will be separate to any cross/up conversion one.
    I wouldn't be at all surprised if basic cross/up conversion and simultaneous down conversion was standard in the MPEG2 (and MPEG2/4) decoder/output chips in use in set top boxes. It is so common in the US I would be surprised if it required lots of extra processing to be added internally to the box.
    However the de-interlacing from 50i to 50p may not be the highest quality - and external scalers may be better at this.
  6. wilno
    wilno
    Feb 14, 2005
    Thanks for replying,
    Here's hoping the box will be all singing and dancing offering the consumer a never seen before array of features. Yeah right :lease:
    Seriously though, if the cheaper option for them is to base the new box on American hardware already out and proven (with reciever scalling) this must surely be a better deal for all.
    Regards
    Wilno
  7. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    didnt I hear that thompson where making the boxes ?
  8. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,371
    +820
    Yep - though I suspect the chipsets used will be the same for MPEG4 boxes sold in Europe and the US (where MPEG4 is also being adopted). They could easily be developments of HD MPEG2 chipsets and offer similar functionality.
    Whilst Thomson is a French company - I believe they also own RCA in the US - who manufacture(d) ATSC receivers for the US HD market?
