71ft LED strip installation Beginner please help
Discussion in 'Home Cinema Buying & Building' started by SohaibZee, Aug 15, 2013.
  1. SohaibZee
    SohaibZee
    Aug 15, 2013
    4
    Manchester, UK
    I have 2 weeks to install some LED mood lighting in my living room i want it to be a surprise for my mum, when she gets back from holiday, also i have absolutely zero electrician experience i study finance and i don't really know much about the terminology either. So if you could factor this in to any replies it'd be much appreciated.
    I had originally thought i'd just buy a 20m strip roll of RGB LED's and then and additional 5m roll hook up an RGB controller and a transformer and everything would be fine, but after reading a few blogs it looks like it's not that easy :facepalm:, some blogs are talking about RGB amplifiers and i have absolutely no idea what type of transformer to buy.
    Also i am quite unsure about how to connect two separate strips of LED's or if i need to cut a strip to make it fit how or what i would use to re-connect it to the rest.
    If anyone could offer any help it'd be much appreciated, preferably on a step by step basis, if that's ok.
    :lease:
  2. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    Portsmouth, Hampshire, UK
    +166
    If you go for 30 LED/m strips rather than 60, and an LED controller rated at 5A/channel or more, then the wiring is quite straight forward as you won't need an RGB amplifier - see attached.
    So, for 22m of 30/m RGB strip, you can see that a 15A or 20A power supply (switched mode supply- we don't use 'transformers' any more) will be required. The cut points on 30/m strips are every 10cm - just use a sharp stanley knife.
