7134 based TV Tuner £29.99 at Aldi
Discussion in 'Shopping, Deals, Discounts & Bargains' started by gingercat, Jul 4, 2003.
  1. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    Medion PV Tv Tuner Card £29.99
    http://www.aldi-stores.co.uk/specials_01_11/offers_nav.htm
    "Upgrade your computer with this card and access TV, FM radio and teletext to your monitor. The software also enables the digital recording of television programmes onto your hard drive. The unit contains the state-of-the art Philips 7134 chip set giving ultimate reliability."
    Think it's a 1 week only offer starting next thursday (10/07/2003)
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Hmm from the looks of it could be similar to the Lifeview 3000
  3. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    Is that good or bad?
  4. Loafer316
    Loafer316
    Apr 8, 2003
    330
    If you check out the sticky in the HTPC forum it'll explain a bit more...PB-TV100 from pcworld is a card based on the phillips 7130 chip and is pretty good ..(i have that one) and i believe the 7134 chip has the extra nicam and and the fm tuner. should be a good card.....but wont really know until someone gets one.
  5. Blighty_Boy
    Blighty_Boy
    does this card accept direct video in ie composite or is it UHF only ???
  6. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    It has SVideo and Composite in too, shall we form an orderly queue ready for Thursday then? ;)
  7. bluefish
    bluefish
    Mar 5, 2003
    37
    Ireland
    Can the Medion PV Tv Tuner Card be fitted to all computers (including laptops)? and is it easy connect up, or is it advisable to get someone with technical competance to do it?
  8. nathan_silly
    nathan_silly
    err how on earth can you fit a PCI card into a laptop????:confused:
    It'll fit into PC's with a spare PCI slot.. switch the PC off. Remove the case.. remove the blanking plate. Slot the card in. Screw in the screw over the blanking plate.. put case back on, switch PC on.. install drivers.
