7" Widescreen LCD TFT Television
Discussion in 'LCD & LED LCD TVs' started by StooMonster, Nov 6, 2003.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Want a small widescreen (16:9) LCD for kitchen?
    Check this out...
    [​IMG]
    7" Widescreen TFT Portable TV
    · 7" Widescreen TFT LCD TV
    · Multiple screen modes (4:3, 16:9 and Zoom)
    · AV inputs to enable use as a monitor
    · Runs from batteries, mains power supply or car cigarette lighter socket
    · Plug-in mains adaptor included
    · In-car power lead included
    · Full function remote control
    · Supplied with full range of connectors and a mount
    This TV features a 7 inch widescreen high-resolution active matrix display colour screen and a built in loudspeaker. This versatile TV can be powered from a car cigarette lighter socket using the supplied lead, from the mains using the supplied plug-in mains adaptor or by 10 x AA batteries (not supplied). Other features include automatic on screen tuning, a headphone socket for personal listening, brightness and colour controls and a remote control. Accessories supplied include headphones, a dash mount, an external aerial adaptor and an AV lead for connecting to external devices such as a DVD, VCR or camcorder.
    Currently on sale until 24-Dec-03 at
    http://www.maplin.co.uk/default.asp?CartID=10954772&userid=newsletter&targetmodule=37366 reduced from £349.99 to £174.99
    Anyone seen one of these in action? £175 for a widescreen LCD albeit 7" size is not a bad price.
    StooMonster
  2. Squiffy
    Squiffy
    May 23, 2002
    9,666
    Ashford, Kent
    +2,819
    Has this got a Scart socket by any chance? It'd be great in our kitchen with a video sender from our Sky box.....
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    OK, did some research with Google.
    SAKA are chinese, and in Hong Kong one can find detail on this...
    Monitor, Tft 6" Saka #CT-V600 (PAL) *B2, S3
    [​IMG]
    Reception Frequency:
    - VHF-1 48.25 - 93.25Hz
    - VHF-3 168.25 - 224.25 M Hz
    - UHF 471.25 - 863.25 MHz
    Screen Size:
    - 11.52cm x 8.42cm diagonal 14cm
    Resolution: 960(H) x 234 (V) pixels
    Although many of these screens refer to "dots" as pixel resolution meaning you can divide the horizontal resolution by three (three dots of red, green and blue make one pixel).
    Therefore, resolution: 320x234 pixels.
    Another common resolution for 7-inch 16:9 TFT LCDs is 480x234 as used by Panasonic and Pioneer in their 7-inch screens (for camcorders). These are often refered to as 1440x234 dots.
    Xenarc
    From the USA we get two screens from Xenarc, both of which boasting 800x480 pixels in 16:9 resolution over 7-inch diagonal, the 700Y and the 700YV with VGA input (supports input up to 1600x1200). Both screens have brightness of 300cd/m x m.
    This one looks similar, at least has the same remote control, and is on many US discount websites
    Product Details: LCDDigital 7-inch TFT LCD Color TV/Monitor
    [​IMG]
    Take your entertainment with you with the LCDDigital 7-inch LCD color television/monitor. The LCD-27 is a battery-powered, cable-ready television/monitor. This fully functional portable LCD monitor features a built-in tuner that works off an external cable system or its own antenna. A built-in telescoping antenna allows the tuner to access VHF coverage from 2-13, and UHF coverage from 14-69.
    Count on Overstock.com to deliver great deals on electronics and accessories everyday!
    Features include:
    - 16:9 wide-screen aspect
    - 4:3 standard aspect support without distortion {zoom mode I recon}
    - Telescoping antenna
    - 160 preset channel tuner
    - Timer
    - On-screen display
    - Image display control
    - NTSC color system
    - Desktop stand
    - USB cable with breakout connections for video, sound, and DC power
    Specifications:
    - Power consumption: 9.5 watts
    - Power requirements: 12V DC
    - Battery holder: 10 AA batteries
    - Display type: 7-inch TFT LCD screen
    In/Out connections:
    - Composite video (RCA)
    - Line, mono audio (RCA)
    - Headphone
    - Antenna (in)
    - 12V DC (in)
    http://www.overstock.com/se/LCDDigital_7inch_TFT_LCD_Color_TVMonitor.html
    Wonder which one this screen is closest too? Perhaps Maplin would answer an email or phone call about it.
    StooMonster
  4. BuyCleverStuff
    BuyCleverStuff
    Jan 10, 2006
    76
    11
    Flintshire
    +3
  5. kijanu
    kijanu
