7 feet away
Discussion in 'Plasma TVs' started by andya, Jul 13, 2003.
  1. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    im thinking of getting a plasma do you think 7 feet away is a little to near for a 42inch ,the room im putting it in is only small.any comments would be apreciated
  2. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    Sounds too close to me.
    Gary A
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    andya
    If your after the 'at the movies' in your face type effect then yes for some 7' is acceptable - I have seen a few 42" displays in small rooms (sitting at the end of a bed in a bed sit was the smallest) and whilst its not for everyone its not the end of the world either.
    And of course we do have the 'in your Jacuzzi' option - which is definitely not 7' away if your sharing the Jacuzzi :)
    See http://products.jacuzzi.com/nd/WpbProdInfo.d2w/MAIN > Private Collection > La Scala
    Best regards
    Joe.
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    We sit 9 feet from the Hitachi 32 incher and it seems right to me - a 42 inch model would be too big imho
  5. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    I sit 9ft away from a 37" panny, ideal compromise IMO.
    James
  6. mw3cdj
    mw3cdj
    Nov 12, 2002
    396
    West Wales
    I sit 8ft away from my 42pma400 and i think its great . As long as you have a good pic, no artifacts ect, then 7' is ok.
  7. G Funk
    G Funk
    Jun 12, 2003
    16
    I am using my Hitachi 42PD3000 in a small room (my bedroom).. not sure on the actual distance.. will check when I get home.. but I think its about 7ft.
    Looks gorgeous and I love it!! (especially with the PC)
  8. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    have you got it on a stand or a wall bracket and is it at eye level or are you looking above
  9. G Funk
    G Funk
    Jun 12, 2003
    16
    It is on a wall bracket and at eye level. I have just measured the distance and it is 7ft
  10. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    could you do me a favour and tell me what the depth is with the wall bracket attached i would guess about 5 inch hopefully its less
  11. G Funk
    G Funk
    Jun 12, 2003
    16
    no problem!
    It is exactly 5 inches.
  12. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    thanks
  13. jmack
    jmack
    mine is about 8ft
  14. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    it looks good my wall is false so im getting a joiner in hes going to put a peace of mdf and shelfs attached to that so with that im probaly looking 6 and half feet i suppose if it to big i could swap it for a 32 inch model depending were i get it from
