7" Digital Photo Frame @ eBuyer
Joined
Apr 19, 2008
Messages
1,232
Reaction score
299
Points
336
Location
Wigan
Not the best resolution but I doubt it makes a difference at 7" and this price, worth a look if you're after one.
Branded 7" Digital Photo Frame - Includes Clock & Calendar Function £14.99 FREE Delivery @ eBuyer
Select *Within 5 Working Days (Super Saver)* to get FREE Shipping :D
Key Features:
- Auto image rotation
- Multi Photo Slideshow
- Supports SD, MMC, and MS cards
- USB 2.0 hi-speed interface for flash memory sticks
- Calender and clock function
Specifications:
- 7" Widescreen TFT LCD
- Display Resolution: 480 x 234
- Contrast Ratio: 300:1
- Brightness: 200 cd/m2
- Displays JPEG Photo Files
- Photo slideshow mode
- SD, MMC, MS, card slots
- Full-size USB port for use with flash memory drives
- Wall-mountable design with detachable stand
- Dimensions = 19.8 x 13.2 x 2.8 cm
Branded 7" Digital Photo Frame - Includes Clock.. | Ebuyer.com
The resolution does make a difference at this size, if you think about it even at 800x480 a 7in frame is still much lower resolution than a smartphone which often have the same resolution on a screen half the size. Any of the 480x234 frames I've seen are noticeably low resolution and not something I'd buy no matter how cheap it was.
John
I have two 7" photo frames. One Sony and the other Texet. The Sony is fantastic as you would expect, but the Texet is truely unusable. So even though the Texet was about £15, it is £15 completely wasted because I can't use it, it is so bad!
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
