7.5 metre component cable needed - where to go?
Discussion in 'Projectors, Screens & Video Processors' started by stormywhether, Aug 11, 2003.
  1. stormywhether
    stormywhether
    I'm fast learning that you never get stuff right first time in this home cinema game. I lost count of the number of bits I've replaced already, due to wrong lengths through shifting components around and so on!
    The latest gaffe - moving the projector on to a wall-mount, and now realising my component cable is too short!
    Anyone recommend a place selling not too shabby decent length component cable?
    Also on a separate note - I got my Keene RGB to S-Video convertor last week to route Sky through to the projector (AE100). Impressed already, but the SCART lead from the digibox to the convertor is one of them rubbish gold plated Argos numbers.
    Would it make a big difference getting, say, a Thor cable or something?
  2. dragonfly
    dragonfly
    Aug 4, 2003
    141
    surbiton
    +3
    Stormywhether,
    I got my 10m tri-component cable from QED Qunex SRCV A bit pricey though, it cost me about £300.But what you get is quality.
  3. stormywhether
    stormywhether
    crikey dragonfly - WAY out of my price range - by about an extra nought, to be precise!!!
    The projector only cost me double that!
    Thanks for your input though.
  4. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    £300! :confused:
    Mere mortals prefer:
    CPC
    or
    Unbeatable
    These are 10m though not seen many 7.5m ones ;)
    -- Jon
  5. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,471
    Surrey. UK.
    +2,117
  6. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Just reading through this thread and seen the £300 price tag on the cable, wow. No offense dragonfly on you spending that amount , its your dosh.
    But as my title says can you really see that much difference in picture quality by paying that much more. Dont mean by having to look hard for a bit less quality in the background but by just sitting and seeing overall clarity. Not just for visual cables what about sound as well?eg, coaxil cables which can be so expensive.
    Nice to hear your opinions,
    Take care ,
    Phill
  7. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    If you are not adverse to a small amount of soldering I would strongly suggest you buy the cable and connectors from http://www.vdctrading.co.uk
    They sell top (broadcast) quality Van Damme cable and connectors. You can make to any length you require and you will be hard pressed to find better cable even at double the price. The items you will need will be
    Red cable: 268-307
    Blue cable:268-309
    Green cable:268-308
    Phono connectors: 306-037
    HTH
  8. Pete Ear
    Pete Ear
    The Van Damme cable is good quality low cost stuff. However it falls short in the shielding department and if you are running parallel to power cables or electrical conduit over several meters, then you would be better off with a dual foil/braid screened cable instead of the single braid screen of the Van Damme. Yes it is broadcast standard and widely used by the BBC etc., but some of us in the AV domain have more exacting standards ;).
  9. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    I have two 10m Van Damme component cables and can only sing there praises.:D
  10. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Thanks Pete
    I wonder if this was the cause of the vertical banding on my LPX all the time? Possible, as my 10m (Van Damme) component cable is routed through the ceiling where there are also lots of pwer cables.
    I have no doubt at all that there is better cable out there but I still believe for the money Joe Public will be hard pressed to beat it. It's also gr8 stuff as it is very flexible which makes for easy handling too.
    You may also like to add where one can buy the type of cable you are referring to :) Always good to have a positive to counteract the negative ;)
  11. gwbailey
    gwbailey
    I'll second that...?
  12. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    I recommend
    www.intoav.com
    for your cables.
    Suppliers of cable to the BBC - so they are well used to making long run quality cabling:lesson:
    Cap:smashin:
