7.1 speaker setup
Discussion in 'AV Receivers & Amplifiers' started by viewer, Dec 27, 2004.
  1. viewer
    viewer
    Sep 26, 2004
    91
    I understand that most films are only capable of 5.1 sound. So whats the point of having a 7.1 system .If I have 4 satellites speakers (in addition to centre and fronts) what to the other 2 Satellites do. Where's the best place to position them, at the rear of the room or at the sides.
  2. viewer
    viewer
    Sep 26, 2004
    91
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    Yep as you've probably found out, some dvd's (like LotR) have DD EX & DTS ES for 6.1 or 7.1 matrixed sound.
    The speakers should be positioned as follows, surround rears at your side & back rears behind you.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,007
    71
    Bracknell
    +86
    Dont forget that the dolby prologic 2x also upsamples anything to 6.1 or 7 speakers.
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    Most new amps & receivers will have this functionality, so you're safe there!
