7.1 speaker question.
Discussion in 'AV Receivers & Amplifiers' started by jookster, Feb 11, 2005.
  1. jookster
    jookster
    Is it ok to have the rear speakers higher than the side speakers in a 7.1 set up.
    My chair is against the wall, and the only place I could have the rear speakers is on the window sill which is 18 inches above my speaker stands.
    Would this throw the sound out hugely?
  2. AvAl
    AvAl
    Oct 16, 2003
    141
    Southport
    Hi Jookster,
    Personally, I wouldn't have thought so. Depending on what amp you have, you can alter settings for both distance from the listening position, side and rear placement and high and low. If you measure the distance from your listening position accurately, I doubt you should have any problems and the amp will sort out the rest, though I believe a maximum of 6 feet above the listening position is preferable - 18 inches...nothing to worry about :)
  3. Astaroth
    Astaroth
    Jun 22, 2004
    2,254
    48
    London
    +97
    It shouldnt be a problem, particularly if you are using bi/di-polar speakers as these create a non-unidirectional sound. If you are using mono-poles it will probably be slightly more noticable but the best thing to do is to try it out and see for yourself
