7.1 Speaker Arrangement
Discussion in 'TAG McLaren Audio Owners' Forum' started by Mr Yakimoto, Feb 4, 2005.
  1. Mr Yakimoto
    Mr Yakimoto
    Jan 20, 2005
    535
    Kent
    +27
    I would like to utilise the 7.1 Channels my 32r has but I am having problems regarding Back Speaker placement.
    The Back Wall is out of the Question (there is a framed Artwork there and the misses will not allow it to be moved......fare enough).
    Has anyone had any experiences with ceiling (in wall) mounted speakers firing downwards?
    I know the hardcore of you guys will probably frown on such arrangements but I havent got a dedicated AV/Listening room and I would like to keep my living room as asthetically pleasing as possible.
    I belive this may be my only chance of hearing 7.1 material.
    Kind Regards
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Id go for it, the surround backs dont do much work anyway so its not essential that you have to have a super high quality speaker :) Both KEF and Monitor Audio do a good range of in ceiling speakers :smashin:
  3. PhilB1234
    PhilB1234
    Also, all rear channels are mixed for a high position anyway. So having them, back and overhead should give good results...
    Have you got a DP? If so, don't forget there's an option for overhead speakers!
  4. Mr Yakimoto
    Mr Yakimoto
    Jan 20, 2005
    535
    Kent
    +27
    Thanks Fellas for your replies :smashin:
    I certainly do have a DP, so this looks quite promising.
  5. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    I run 7 in-ceiling speakers for the same reasons - I use 7x M&K SW-150s with a AV32DP/250x3R/100x5R. Sounds great to me :) If you're ever down this way you're welcome to pop in for a demo.
    Colin
