7.1 Sound: Why?
Discussion in 'AV Receivers & Amplifiers' started by JamesL, Feb 25, 2005.
  1. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    I notice many medium/upper end receivers offer 7.1 surround outputs. Other than multiroom setups (5.1 plus stereo in another rm) does this have any other application? Virtually all films have 5.1 sound, a few Dolby/DTS EX have 6.1. I haven't seen any that have 7.1. So what is the benefit of 7.1 on a receiver? Do the receivers offer some sort of audio 'upconversion' or is sound from 5.1 channelled to both surrounds and rear speakers?
    I would greatly appreciate it if someone could explain!
    James
  2. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    Actually the 7.1 is a bit of a strange one, you only have 6.1 discrete channels, the two rear back channels are run off of the same source. I use 6.1 as it helps fill in the sound stage at the rear, and it makes a difference compared to 5.1
    I would imagine if your room was sufficiently large the extra rear channel would make a difference, in my case it would be overkill though.
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    can you run two speakes off a the rear channel? ie make a 7.1 from a 6.1 amp?
  4. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Thanks for the replies guys,
    So the receiver basically is 6.1 just outputting the centre rear twice? How about with 5.1 content, are the rear speakers silent or are the left/right surround simply duplicated by the extra speakers?
  5. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    No mhuk05 it wouldnt be advisable. Whilst a 7.1 amp only actually plays 6.1 channels it has seperate amplifier circutry for the 2 rear channels (though it plays the 2 in mono).
    with a 7.1 amp you really have a choice of 3:
    Use 7.1 surround sound (either matrixed or discreate for the rear 2 channels)
    Use 2 channels for multiroom uses
    Use the rear 2 channels to bi-amp the front L&R in a 5.1 setup - some amps have native support for this others you can do this by using the preouts and reinputing these as a new source and con the amp to think it is outputing in multiroom.
  6. tpc3416
    tpc3416
    James,
    Another way to take advantage of the additional 2 channels would be audio vs dvd. If your room allows or is large enough, place your video surrounds to the sides of you, and your audio surrounds behind you. Some claim you get better sound from behind with audio and more realism with movies at the sides. So you can switch based on your listening preference. Some amps also have a 7.1 "stereo" mode feature which utilizes all 7 channels by basically reversing the stereo in the 6th and 7th rear speakers, making them true reverse stereo. I have that, but it seems there is so much going on you can't tell the separation as well with all the drivers. I think it's best used for either bi-amping or for a secondary room.
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,590
    Rainham Essex
    +2,543
    Apparently if useing a single rear speaker the sound confuses the human brain and it can't tell that the sound is coming from the rear. By adding a second rear speaker the brain works out that the sound is 'behind you'.
    Most modern receivers will have Dolby Pro Logic 2 & DTS Neo6 that can give a 6.1 surround 'effect' from a stereo source ie driving all the speakers and removing some sound from the L&R and outputting it from the surrounds.
    Some of the newest receivers have DPL2x that can do a similar effect as DPL2 but with any source from stereo up to 6.1 and give a 7.1 output, ie all 7 speakers are outputting an individual sound. Lexicon have something similar called 'Logic 7'.
    Mark.
  8. Diamond
    Diamond
    H/K 335 also has Logic7.
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,590
    Rainham Essex
    +2,543
    Yes, they may well have Logic 7 but they licence it from Lexicon who wrote it in the first place.
    Mark.
