7.1 Room Setup
Discussion in 'Home Cinema Speakers' started by firstwave, Jul 11, 2004.
  1. firstwave
    firstwave
    Sorry if this is in the wrong area, but it seemed the best choice.
    I am looking at buying a 7.1 amp and 7.1 speakers.
    My concern is that the seating area is against the back wall, and with my current 5.1 setup I have the rear speakers to the side of the seating area which is fine.
    With two additional rear speakers, will I have a problem with the sofa being against the wall, and hence the two rear's directly above it?
    Darren
  2. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    Possibly. I am in the same position which is why I have stayed with 5.1
  3. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    I'm in same boat as well (centre/back sofa can only go against a wall), so I think this is relevant to this thread. I also have a door in the back, right corner meaning I cannot have two rear speakers on the side walls, unless I place them higher up so that that the right rear can clear the door frame.
    What rear speaker positions (kef eggs 2005.2) would you recommend - back wall or side walls, but higher up?
    :lease:
  4. Jon
    Jon
    Same here
    Jon
  5. sraper
    sraper
    Aug 7, 2001
    798
    Watford, UK
    +254
    How about in-ceiling speakers :eek: Not sure if the would work as they would be firing straight down! Maybe worth a try?
  6. firstwave
    firstwave
    Well I have bit the bullet and just ordered a Yamaha RXV650 and 7.1's worth of Mordaunt Short Premiers.
    I will post back once setup and let you know if it does sound ok in this layout.
