Alcopoppa
Established Member
Hi all,
I recently purchased some 5.1 KEF T101 speakers and installed them. However I stupidly didn't do any research on speaker position and got the side/rear speakers in the wrong place completely - they are behind me rather than at the side and too high, so I don't get the surround effect. Unfortunately I can't get the trunking I used off the wall without ripping off half the wall with it, so have to keep them there. I was therefore thinking of buying some fairly cheap speakers to use as the read speakers in a 7.1 setup, and moving the KEFT101s to the correct side position (and having the cheaper speakers as the rear ones where the KEFs currently are)
So, I am wondering if anyone has any recommendation for some fairly small, fairly flat (if possible) speakers that I could wall mount and use as the rear ones? I don't want to spend £300 plus on another pair of KEFs; my budget is max £150 but would prefer to keep it at £100 or below if possible.
Thanks in advance.
Thanks in advance.
