7.1 on the 3802?
Discussion in 'AV Receivers & Amplifiers' started by keyser, Apr 21, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Does the 3802 ever display "7.1" on the display. I have two back speakers and it doesn´t matter if I have the back surrounds set to matrixed or to non matrixed the display always says 6.1. Is 7.1 maybe when it says "discrete"?
  2. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    I have not managed to get it to say 7.1 as yet. 6.1 refers simply to surround back being active whether one or two speakers is used, I assume. I have played all the available sound fomats on it and that is all it says. I have only had my 3802 for a few weeks so maybe some0ne with some technical information on the displays out their. Do you like the machine.
    Mark
  3. Jase
    Jase
    Mar 16, 2001
    10,815
    United Kingdom
    +2,693
    It wont display 7.1.
    For DTS Discrete it will show 6.1 as well.
    Technically there is no 7.1 format, its actually 6.1 but on some amps you have the 2nd rear centre channel.
  4. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Jase it right, until Star Wars II comes out ;-)
