7.1 for 5.1 sources?
Discussion in 'Home Cinema Speakers' started by MarkHudds, May 28, 2003.
  1. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    A question for those with 7.1 systems ...
    Do you force 7.1 on your amplifiers all the time, even for 5.1 sources, or do you find that a 5.1 source sounds better just from the surrounds rather than 'matrixing' with the surround backs?
    I'm using a Pio AX10 with two pairs of MA Silver fxi's as surrounds and surround backs. Should I keep the amp set to 'Auto' or always have 7.1?
    Not sure why, but the AX10 auto setup (using supplied microphone) sets the surround fxi's as LARGE but sets the surround backs as SMALL ?!??!
  2. jonnyv
    jonnyv
    Mar 31, 2002
    2,279
    48
    +52
    I have a 7.1 system and only use it when the source material uses the surround back speakers, i always stick to the original sound format.
  3. morg
    morg
    I also have a 7.1 system, but leave it on 7.1 all the time as could
    not tell the difference between 5.1 or 6.1 when using matrixing
    for rear speakers. Your amp probably sets rear speakers to small
    as default as there are not many rears capable of outputting loads of bass.
