YamahaLover1975
Hello. New here so after a little advice if you wouldn't mind.
Have recently purchased a Yamaha DSP-AX759SE amp, and want tips on connections and speakers on the following.....
1. How do you get the OSD to work and what video output to a screen do you use?
2. I have a Bose Acoustimass 5ch system. As the amp is a 7.1, whats the best way, if possible, to have it set as a 5 speaker system? I don't have an active sub, just the passive Acoustimass module thats wired with the speakers thru it.
I do have a pair of Bose 501s, if needed I could connect these, but they are a bit too large for the room atm.
3. I mainly use the amp to play sound fed via optical link from back of TV. Any tips or essentials in the settings I need to look at?
4. Any other tips on settings etc you people suggest??
TIA. Mark
TIA. Mark
