7.1 Amp and Speakers for PC
Discussion in 'AV Receivers & Amplifiers' started by dj_ooms, Jan 11, 2005.
  1. dj_ooms
    dj_ooms
    Nov 28, 2004
    162
    +23
    I am looking for a decent 7.1 amp for use with my PC and XBOX. I will definitely need optical input for the XBOX. I have an Audigy 2 soundcard with 7.1 output and would like to connect this to the amp using analogue connections specifically for gaming and music. I would like to get the maximum from my PC, so would like the amp to have 7.1 channel input. My budget is not very high probably £250 for the amp, but am willing to go higher.
    I am also looking for a decent set of speakers to use with the amp - 7 satellites and a subwoofer. Again my budget is not very high but want decent sounding speakers for music. I don't want to spend more than £200 on the speakers but may go a bit higher. I listen to bass heavy music but want clarity throughout all frequencies. Getting all 7 satellites straight away is not a priority. I would at least like to get a 5.1 setup with the option of upgrading to 7.1 in the future.
    Thanks in advance for any suggestions.
    Oomar
