Quantcast
7.1/5.1 Speaker Wall Sockets
ziglar
I have run some cable around my Home Cinema room and I am now looking for some wall sockets that will allow for the connection of all speaker cables that come thru the wall into one panel for connecting to the amp.
I have seen some on the hiddenspeakers.com website that fit a dual gang socket but I was hoping for some other choices as well.
BTW is terminating the speaker cable at a wall socket and then running some short cable from the wall socket to the amp the best solution OR should I just run the cable out thru the wall for direct connection to the amp?
Wrong forum - but any recommendations for a decent mid-price 7.1 amp?
Stuart Smith
ReTrO
It will be cheaper, easier and more benficial (read; less ditrimental) to your sound quality to just have some blank plates with holes to run the cables directly through.
:smashin:
windfall
I purchased a load of these speaker plates on ebay.
They turned in at just a few pounds each and purchased an AV panel as well that allows all the standard video connections to be plugged into a standard wall socket.
It looks neater, if your interested PM me and I'll give you the email address of the seller who supplied me.
Tone
