Bristol Pete
As above, is the difference between 6mp and 8mp that much, when shooting, printing etc...?
Thanks,
Pete.
Thanks,
Pete.
I'd do some thorough investigation into what cameras you are comparing in terms of image quality before worrying too much about megapixel count.
Captain Benefit said:Personally, I cant see myself going over 7 x5 but you never know....
Is 300 x 300 dpi the max anyway?
Thanks.
T0MAT01 said:I know what you mean, but once you've got a taste for photobox's 10" x 15" it's hard to resist.![]()
As for the max dpi, the Canon i9950 says it will print 4800 x 2400 dpi!![]()
mr jones said:print resolution is a completely different onion to DPI.
300dpi in an image is pretty much a standard for the likes off magazines and publications, most cameras will output at 72dpi (web resolution) unless you tell the raw software to do otherwise.
resolution does go higher than 300dpi but for most applications this isnt required
the way the numbers are calculated means that it is not a staight-line function.Captain Benefit said:is the difference between 6mp and 8mp that much,
richard plumb said:printer dpi doesn't really bear any relation to the original image. They may say 'five squillion dots per inch' but that has to cover them having to mix lots of only 3 or 6 coloured dots to make the original dots. So one dot of your original image will be many dots of printer ink.
Captain Benefit said:Am doing that exactly, hence the 6 v 8 question.
Thanks.
