6kg speakers onto partition wall?
Discussion in 'Home Cinema Building DIY' started by pistolpete1, Feb 18, 2014.
  1. pistolpete1
    pistolpete1
    Jan 17, 2009
    1,501
    +130
    Will it be safe to use a pair of b-tech bt77 wall brackets and mount some 6kg (each) speakers onto a metal studded partition wall without fixing to a metal stud?
  2. Ghostrider
    Ghostrider
    Jan 3, 2006
    884
    43
    Warrington
    +127
  3. Mister_Tad
    Mister_Tad
    Jan 16, 2008
    516
    3
    Nottingham
    +348
    Over-engineer it if you have any doubts... I always do.
    I'd go for some hollow wall anchors and a setting tool, like so Hollow Wall Anchors | Cavity Fixings | Screwfix.com
    I've got some heavy MDF cabinets up with these, can also use them for radiators etc, so a couple of speakers aren't going to be an issue.
  4. pistolpete1
    pistolpete1
    Jan 17, 2009
    1,501
    +130
    Thanks guys.
    I was going to use those hollow wall anchors, as I put a TV up on a similar wall with 2 of the anchors holding an extendable arm bracket and TV. Just looked at the TV spec and it weighs 5.3 kg, so with three screw holes on the btech speaker bracket I should be OK.
    Just don't want the top one to pull through the plasterboard, as that one will take all the weight/strain due to the speakers being extended out some way from the wall due to the wall bracket/depth of speaker.
