660GT again
Discussion in 'Desktop & Laptop Computers Forum' started by RobsterD, Jan 12, 2005.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Well I got an XFX 6600GT agp card and installed it on a newly formatted sata drive.
    What a noisy beast :eek: so I put the Zalman VF700 cooler on it.This was a bit of a pain the heatsink even tho secured still seems to rock a little,temps are around 38°C so I'm presuming it's fitted OK,it also only just fitted into my Silverstone case so beware if you got a slimline case it may not fit
    Tested with TT2 with default setting and not impressed with PQ so far,have since updated Nvidia drivers to ver 66.93 and messed around with VE and Avia,but still the PQ is no better than my old Radeon9500 pro.
    Have since also introduced ffdshow into the mix to try and improve things and have had an astounding picture but with dreaded stuttering.
    Been trawling TT and AVSforums but I'm going round in circles.
    What I would like is scoped TT2 settings for the 6600GT card and what TT video setting are reqd for best PQ utilising ffdshow.
    Any help would be greatly appreciated
    Sometimes I think if it works leave it well alone and DONT upgrade cos market forces expect you to. :laugh:
  2. UrbanT
    UrbanT
    Jan 6, 2002
    12,847
    Aldershot, Hants
    +3,032
    Rob, I bought a 6600GT AGP for my HCPC, this was to replace my 9800 pro. I had read much about improved picture performance.
    I couldn't spot any difference at all in quality, and couldn't eliminate some stutters I was getting either. Having spent hours reformatting, trying different drivers and PC settings, I decided to put the 6600 in my normal PC, and keep the 9800 which is doing a superb and trouble free job. :smashin:
  3. Kahless725
    Kahless725
    It wont be the video card that is causing the stuttering. No video card accellerates FFDshow, FFDshow uses the cpu to calculate the picture resize etc.
    Try pulling the settings back a little.
    As for the 6600GT if I didnt have a graphics card then this is the one I would go for but if you have a 9700 pro or 9800 pro (I have a 9700 pro) then personally I wouldnt bother as the 6600GT only accelerates windows media.
    Robert
  4. Kahless725
    Kahless725
    Huh I posted after UrbanT's second post but its stuck my post as number 3? Look at the times :) ????
  5. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
  6. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Cheers just been trawling thro TT forums for some helpful info,thanks for the link :thumbsup:
  7. UrbanT
    UrbanT
    Jan 6, 2002
    12,847
    Aldershot, Hants
    +3,032
  8. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    if u want to get Hardware Optimised DVD playback on 6600 cards u need the NV DVD decoder
  9. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Is this not included in TT2?
    TT2 settings are VRM9 and Film Mode and running ffdshow @ unsharp mask 13,gradual denoise 13,Lancros 4 resize 1280x720,luma sharpen .01,YV12 o/p
    Still get sound dropouts without using ffdshow also tried Reclock 1.5beta8 with no luck
    Have since upgraded to Nvidia 71.24.I can get the picture looking real good with VRM9 and ffdshow but get sound dropouts and stuttering,real shame :(
  10. UrbanT
    UrbanT
    Jan 6, 2002
    12,847
    Aldershot, Hants
    +3,032
    I run Theatertek 2.0 which has the NV DVD decoders. Kahless725, I tried all the settings I could find, with and without hardware acceleration, and couldn't get playback as smooth as the ATI.
    As for the posts, I have no idea why they are all being messed up :confused:
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    There are a couple of useful threads on AVS about the nVidia codecs and drivers:
    Drivers
    Codecs
  12. betamac
    betamac
    I just got the MSI PCI Express card 6600GT
    Just waiting for my Nforce 4 board and then i am gona build my Claritas HCPC i am wondering is the VF700 will fit in the case as i have bought one
    What size is the case you used m8?
  13. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    I have not bothered with theaterTek, I simply bought the Decoder and use it in Media player or Media Centre, my CPU never breaks 20% also my version of the decoder is higher by .20 I think.
    Playback of DVD is sweet and TS is smoother then a Kasmirian Codepiece
  14. UrbanT
    UrbanT
    Jan 6, 2002
    12,847
    Aldershot, Hants
    +3,032
    Theatretek update their software when Nvidia update their codec
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I believe that latest codecs released directly by nVidia are 1.0.67 (aka. 4.0.67, gets confusing).
    And I have to say .TS files are far from smooth for some. :thumbsdow
  16. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    are u sing a Geforce 6600 card
  17. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    The case height of my Silverstone is 6" any less and I doubt it will fit does depend on mb standoffs etc
    Who me ????
    Thanks guys for replies will have another play tonite got Donnie Darko Directors Cut delivered today :D
    Rob
  18. betamac
    betamac
    Well i have not tried fitting the Zalman yet so not sure if it will fit, for now i am just experimenting i have unplugged the Fan on the MSI 6600GT and currently been runnign it all day with no problems the Core threshold on the nvidia software shows 127C (seems damm high but why would they put that there if it was not relevant)
    anyway the core is running at about 70c with no fan on and causing no problems so far
    I tried this with my galaxy AGP and it crashed after a few mins but i know thats because of the extra chip the AGP cards have which bridges from PCIe to AGP which gets very hot
    Will see how it goes if it gets too hot will fit the zalman
  19. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    Ive just fitted a Zalman FanMate to the fan on my XFX 6600GT, then truned it down just about all the way. Peace at last.
  20. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    I have one of these. Let us know if it stays stable or blows up.
    Ken
  21. Yaka
    Yaka
    Dec 20, 2000
    1,663
    2
    63
    +110
    try using VLC its much better at handeling .TS files
  22. betamac
    betamac
    Normal Windows Use And Watching movies it seemed very stable max temp was about 95 - 100c maybe sounds alot but well within the core threshold
    But i did not try in games as i was worried it would sky rocket the temp, i have now fitted the Zalman and it does fit inside my case and is very quiet
  23. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    Thanks Mac, I may fit a Zalman myself; although the noise of my projector pretty much drowns out the hcpc.
    Ken
