6600gt and AE500 problem
Discussion in 'Desktop & Laptop Computers Forum' started by dazzer123, Mar 27, 2006.
  1. dazzer123
    dazzer123
    Sep 30, 2002
    429
    Stoke-On-Trent
    +4
    Hi wondering if someone could help me cure this problem when i use my HTPC for movie watching on my Panasonic AE500 the projector manual says i should display a picture of 1280x720 on the edid1 setting of the projector, but the graphics card i presume is cutting off about a quarter of an inch of the display it is really missing.
    Now when you install the forceware drivers and go through the hdtv set up procedure it says you can adjust edges later but i can not find where to do this and if this could be the answer to my missing display or is it something else stealing my picture from me please help.
  2. dazzer123
    dazzer123
    Sep 30, 2002
    429
    Stoke-On-Trent
    +4
    Anybody have any ideas on how to get my qauter inch of display back?
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    I'm running the same without any probs,do you use powerstrip if yes I could email you my settings for 1280x720
    Also what is your DVD playback software.
  4. dazzer123
    dazzer123
    Sep 30, 2002
    429
    Stoke-On-Trent
    +4
    Hi no i don't use power strip is there any point as the projector only accepts 60Hz at 1280x720 res ? do you have 6600gt and AE500 if so do you use EDID1 on the 500 as the instructions say you should, if powerstrip is beneficial then ill give it a go.
  5. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
  6. dazzer123
    dazzer123
    Sep 30, 2002
    429
    Stoke-On-Trent
    +4
    cheers for that will give it a go.
