65OLED936 Android 11 Firmware
gru1505
Ok i found that there were Android TV update to that new interface (similar to google tv). Why i have the old one? What i need to set up to get that new? You said i do not have set it up fully. What am i missing?
HAM5ter84
You need to just update via Google play store after installing the update and it will roll out the latest version of Android TV home to your TV. The build has the older version of the interface after a factory reset.
gru1505
All seems to be updated. Android TV home and Android TV Services are updated and still old interface.
HAM5ter84
Does it have :
  • Search - Google search Icon
  • Home
  • Discovery
  • Apps
With the input icon on the top left and and the cog wheel.
Or does it have the large icons on the left then large rows.
Philips have deployed the updated Android TV home, that have elements of Google TV, but no Google TV interface itself.
gru1505
This is my interface. So big left icons and then large rows
HAM5ter84
It does indeed look like old Android TV version and you have opened Google play store and then proceeded to install the updates. If you have not sure what is up and maybe dependent on version as definate the / 12 variant has had the updated Android TV home screen and was delivered via the Google play store. Can't help anymore though as this is the only way I believe it is updated. Open a ticket with Philips would be my suggestion.
This is my interface. So big left icons and then large rowsi
Joe Daring
I have seen that same interface on my 55OLED806 a couple of times after a reset, with no apparent reason for the change of interface. The TV returned to the normal, newer interface, all by itself, without me doing anything...
GL!
HAM5ter84
GL!
I believe it's the default build home image for the TVs and then Android TV home app is updated in the background via Google play store. Still feels like the poster hasn't opened Google play store after the update and allowed for the updates to come through.
gru1505
i've opened play store, i've updated manually Android TV Home and Android Tv Core Service via Play Store. I Updated Play Store. I tried everything i could and still no new interface. Maybe it is region dependent. I am from Slovakia, but i didn't find any info about it. On Xiaomi Mi Box S same problem. i didn't receive update.
HAM5ter84
Sounds like it could be out of Philips hands and a Google thing then as most posters on here are from the UK. If it was the one device, but two just sounds like a region thing.
gru1505
Strange thing is that in Slovak manual is section about updating and what are differences between old and new UI :D
HAM5ter84
You could try using a VPN to 'be in' the UK or something and see if that updates it. Honesty you're missing out on nothing though and I wouldn't even care about this if I were you.
To be honest have to agree. It's just moving what is in effect icons from the side to the top and probably making apps a little easier to find, but it's not mind bending different
Drdense
Just got OTA update of R.101.000.178.206 (Taiwan). No released note on screen as usual.
This version is now live on the philips website however according to the change log it is android P which is android 9? Also 2021 tv models are not mentioned in the changelog only 2020 and earlier.
Now this may be philips not updating it correctly (which would not surprise me in the slightest) but I would need further clarification on what this "update" actually consists of before using it.
After checking again this firmware is available for the 935 (2020 model) but not the 936 (2021 current model) so I suspect this is not actually the update people are waiting for.
@darkj2k can you confirm what model of tv you have?
I have attached the changelog from the philips site for people to look at and see what they think.
  • 65oled935_12_fhi_eng.pdf
Priyantha
That's not the same version :)
The PDF you're referencing is about TPM191E, and the screenshot is about TPM211EA, which is the 'current-gen' xx21 range :)
Drdense
It's the exact same software version, I'm not saying that it won't work on the newer models I'm saying that the changelog makes no mention of them and it refers to android p with no mention of any update to android 10 or 11. My questions still remain. As I said in the philips support page it is not listed against the newer tvs, only older ones.
no - it is different ...
2019/2020 Models are using the same platform
-> current version ATV9 TPM191E _ 101.002.178.000 – Date: 2022/05/11
2021/2021 Models are using the same platform
-> current version ATV10: TPM211EA_001.002.114.203 – Date: 2022/03/17
-> some got ATV11 via OTA: TPM211EA_101.000.178.206
[email protected]
Priyantha
Yep exactly ;-)
Samsung QN800B 8K TV Review
Latest News
Samsung unveils Galaxy Z Flip 4 and Fold 4 smartphones
  • By Ian Collen
  • Published
Movies Podcast: 8th August 2022
  • By Casimir Harlow
  • Published
AVForums Podcast: 8th August 2022
  • By Phil Hinton
  • Published
Warner Bros Discovery set to combine Discovery+ and HBO Max
  • By Ian Collen
  • Published
What's new on Sky, NOW and Paramount+ UK for September 2022
  • By Andy Bassett
  • Published
