Question 65m CAT 6 cable run
Breaking Dad
Just about to start a garden office build and just before we put down the base I just wanted to check that a 65m CAT 6 cable run should be OK? Looking on the net it would seem that up to 100m should be fine but just thought I'd check with the experts before I stick a spade in the ground.;)
Kristian
Yes, distance is fine. Think about installation though. Duct grade cable if in a duct, or external cable if above ground, armoured if direct buried. Run two cables to have a spare. UTP, solid core and terminate into modules, not plugs. Keep separate from power by at least 100mm.
If you want to wing it then run normal or external grade in ducting with a draw rope so you can replace it in a few years, possibly.
oh, cat5e will give you the same performance as cat6 over that distance If it helps.
Breaking Dad
I'd be putting fibre in.
Would there be any point in putting fibre in if we're only on copper to the exchange. Current BB speed around 30Mbps.
Puntoboy
Just for an internet connection, no, but there are lots of reasons to have higher speeds internally, but also a few non-speed related reasons to go with fibre. What if you decide at some point to have a file server in the house and you want to access files in your garden office? Having a high speed link between the two buildings would be beneficial there. Adding CCTV in the garden office, again, another plus for higher speeds.
Bare in mind fibre doesn't mean 10-40GB if you don't want it to. 1GB is perfectly reasonable with fibre and is likely what you'll be getting with CAT6/5e anyway.
Fibre is resilient to lightning strikes and interference from other electrical cables. You should also consider ground loops as that's not an issue with fibre.
The cost of fibre isn't too bad, compared to CAT6. There's a little extra cost in media converters depending on the network equipment you have.
Breaking Dad
Thanks for the explanation. I would be connecting this back to a conventional switch and patch panel which is a work in progress. I assume the media converters you are referring to would be to adapt the fibre cable to fit this kind of set up? I'm sure you appreciate I'm no expert when it comes to networking, just picking bits up as I go along, which is why this forum is so helpful. More than likely this would only ever be used for internet connection and Skype calls, and maybe a CCTV camera at some point.
Puntoboy
Thanks for the explanation. I would be connecting this back to a conventional switch and patch panel which is a work in progress. I assume the media converters you are referring to would be to adapt the fibre cable to fit this kind of set up? I'm sure you appreciate I'm not expert when it comes to networking, just picking bits up as I go along, which is why this forum is so helpful. More than likely this would only ever be used for internet connection and Skype calls, and maybe a CCTV camera at some point.
Sign in - Google Accounts
What switch do you have currently? What did you have planned for the office end? A single faceplate with an RJ-45 connector or another switch?
Breaking Dad
Blimey you're quick!:D The original plan just a single RJ45 faceplate at the office end, which I think is what Kristian above meant by 'module', no switch required at the office end.
Breaking Dad
The switch is a TP Link 16 port Gigabit Switch
Puntoboy
So in the garden office end, you could use one of these which converts the incoming fibre to an Ethernet port you can plug your computer into. TP-Link MC220L 1000Base-T to 1000BASE-SX/LX/LH Single/Multimode Fibre Media Converter, via 1GbE SFP Port (10km)
You could also use one at the house end if your switch there doesn't have an SFP port like this one TP-Link TL-SL1218MP 16-Port Unmanaged Fast Ethernet PoE+ Switch w/ 2 x 1GbE RJ45/SFP Combo Ports (192W)
Kristian
Yep, RJ45 faceplate/module as it has the IDC connector to terminate to, and not terminate on plugs :) You can always add a switch later for more ports/devices/AP etc.
Personally, I wouldn't use fibre unless you're planning on needing to run 10Gb or more,have the outbuilding's power on a different phase to the house, or have to run network clipped to power cable. It'll be more costly in terms of cable and equipment needed. Always fun to play though. If you install ducting then you can always pull something else through if you need it. If you're not using ducting then run at least two cables.
/few ways to do this...
Breaking Dad
Thanks all. I was planning to run a SWA cable from the house to the office in a small trench about a spades width, with 40mm ducting for the ethernet cable on one side of the trench, and the SWA on the other to ensure at least 100mm separation. I've got some plastic pegs to keep it all in position prior to back filling.
Kristian
Sounds like a plan. Don't forget the rope in the ducting! Getting the cable down 65m will be, er, fun so try and get the draw rope (and/or cable) in as you go along if the ducting is in shorter lengths and connected together.
Puntoboy
I don't think Cfibre is that much more expensive than copper. Personally I would still go with fibre after weighing up the options.
Breaking Dad
Thanks for your input Puntoboy, you obviously no your stuff when it comes to this kit. I haven't ruled out the fibre, I just didn't' want to have to swap out the switch in the house. Could you just explain what an 'unmanaged' switch is compared with TP switch I currently have. Is it just the addition of the 2 x 1GbE RJ45/SFP Combo Ports?
Breaking Dad
Like I said, a few ways to do this. People have their likes, dislikes and preferences :)
Thanks Kristian, there was me thinking this would be fairly straight forward and it would seem that the options are many and varied. To be honest I want to make this bit as simple as possible as I'v still got to build the bloody thing. I rather rashly promised my wife a shepherds hut garden office, so now the talkings over and I've got to deliver:facepalm:
Puntoboy
I know enough to get my by, certainly no networking expert but I regularly come across it as part of my job.
Without knowing the exact model of the switch you currently have I cannot say what the difference is. Unmanaged just means there is no way to configure the switch so it's plug and play. Managed switches have the ability to configure things like VLANs and more advanced networking features.
As mentioned, you don't need to upgrade your switch if it doesn't have SFP ports, you'll just need two of the media converters instead of just one for the garden office.
Cable - Fibre cable
Two media converters - TP-Link MC220L 1000Base-T to 1000BASE-SX/LX/LH Single/Multimode Fibre Media Converter, via 1GbE SFP Port (10km)
Two SFP modules - SFP Modules
Then you 'll just need a standard patch lead from the media converters to the switch and the device you want connecting in the office.
So yeah, Ethernet cable will be cheaper, but not by a huge amount. EssCable CAT6 F/UTP External/Outdoor PE Ethernet Cable Reel, Black, 305m (Boxed)
Kristian
/sorry, missed Puntoboy's response above.
Un-managed means it's a dumb switch and just forwards frames to/from ports as and when needed. As opposed to managed the switch has intelligence and can support things like mulitple VLANs, statistics, remote access, SNMP, port aggregation, maybe routing capabilities etc. I can't say I've seen an unmanaged switch that supports SFPs, but then I look after kit that's all managed.
Breaking Dad
Cable - Fibre cable
Cheers for the links. I did attach a picture of the switch, not sure if it attached. Its a TP Link TL-SG1016D
Puntoboy
Ah sorry, must have missed that. So yeah, no SFP ports. So you can either replace it with one that does or just use a media converter at that end as well. Personally, I would just use the media converter unless you can think of a reason to upgrade the switch at the same time ;)
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
Latest News
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
Sky Q updates smart features and adds Disney Plus in HDR
  • By Andy Bassett
  • Published
