656a & Progressive Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by Sasquatch, Dec 18, 2002.
  1. Sasquatch
    Sasquatch
    Upgraded my ancient Samsung 709 to s Pioneer 656a,
    I am very impressed, the sound is much better, and colours much more vibrant however . . .
    Progressive scan was one of the attractions, had no idea I wouldn't see the benefits from PAL disks!
    Is there likely to be a hack for this in the future? how can I tell what my player is outputting and can I switch the mode via the menu?
    Help! advice/progressive scan de-mistified please!
    Glad I discovered this forum :)
    Cheers,
    Steve
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Do you have a UK machine? According to Pioneer, it's only the US 656a that has prog scan & that will only work with NTSC. Since (from what I've picked up from US sites) the American's aren't into importing European discs, like we are into importing their's, there won't be a demand to upgrade the US version to include Pal progressive.
    You can tell if the machine you have is not the UK version if you have a button labelled "progressive" to the left of the disc tray. and no FL dimmer button
    If i'm talking twaddle, someone put me right please since if the UK version is prog scan enabled, then that will be a nice bonus for the future (I'm not worried for now since I don't intend to upgrade my TV for a few years yet and it can't deal with PS)
  3. Sasquatch
    Sasquatch
    I do have a UK machine, has 2 buttons on the left of the display,
    not at home so can't remember what they do!
    From the reviews I was lead to believe the machine could cope with progressive scan,
    Bugger!
    Anyone got some info!
    btw am using a projector with component inputs, and am looking to buy a progressive scan telly soon! :)
    Cheers,
    Steve.
  4. bash
    bash
    Nov 10, 2002
    3,166
    London
    +726
    I've got a UK machine and it doesnt have prog scan capabilites, only US and Asian models do Im afraid:(
  5. Sasquatch
    Sasquatch
    I feel a bit daft now! I did so much research I don't know how I got it wrong!
    OK what should I do?
    Return it and buy a DVD player that has progressive scan?
    any recommendations upto £350?
    or be happy that I have bought a decent player?
    Confused?!
    What do you guys reckon, how important is progressive scan? should I be concerned?
    am I a fish?
    l8r
    Steve
  6. Guest
    Hi Steve,
    Easily done mate.
    I've been looking for a new player and that fella is on my list. My friend has one and he raves on about it. He's going to bring it round soon for a demo.
    I've decided to buy a seperate prog scan converter box which will convert everything ( free view, xbox, dvd etc) into prog scan. So that's another way to go...probably talking between 500-700 quid though.
    I don't know what other kit you have but I've only really noticed a benefit when looking at larger pictures(like plasmas & projectors) so if you have a 32" telly I wouldn't worry. I'm sure someone will disagree with that remark.
    Also, I don't think you can get a player with SACD, DVD-A (which you have) and Prog Scan for that kind of price.
    Jus
  7. Sasquatch
    Sasquatch
    OK
    Cheers for the replys!
    It is not too late for me to return the 656A - was told it has progressive scan!
    I have a projector and am in the market for a big telly/plasma so I think progressive scan is the way to go
    questions:
    Not bothered about the other functions of the player, just want to watch films!
    Alternative - Toshiba 510e, any opinions?
    Progressive scan, if I get a progressive scan Plasma or TV, do I need the DVD player to be progressive scan, or can I use the component out and the TV takes care of this?
    confused now!
    Cheers,
    Steve
  8. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Return it and get a philips 963sa :)
  9. Sasquatch
    Sasquatch
    OK
    questions:
    confused now!
    Cheers,
    Steve
  10. Sasquatch
    Sasquatch
    OK, 1st day on the forum, had a read, gonna take the 656a back!
    Not progressive scan and I am buying a big telly soon!
    Any advice/ideas on what to do next appreciated!
    The philips 963sa, and Toshiba 520E are shortlisted!
    Why is the 520e so much cheaper than the 510e!?
    Help, too much input! . . . .
  11. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    the 656 is a great player, if you have a projector and plan for a plasma or prog scan telly why not go for an external scaler that will do for the plasma and pj and de-interlace as well?
  12. Sasquatch
    Sasquatch
    Problem is I have a budget of £350 for the DVD player!
    This Philips 963sa looks promising though, buggered if I can find anywhere that actually sells it!
    I do have a mate who works for Philips though . . . hmmm
    all good advice though, cheers!
  13. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    £350 is enough for the Phlips DVD 963, but they are in short supply this side of the new year.
  14. Sasquatch
    Sasquatch
    Sounds like a plan, is this player really that good?!
    Looks nice, and looked at the manual, has some nice features,
    You lot love it, but nothing in the press or on the web really!
    Looks like the 656 goes back tomorrow, then I have about £2000 to buy a new TV and DVD!
    Help from you guys is much appreciatted!
    Nice!
    l8r
    Steve
  15. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    Im interested to know where you bought the pioneer as i just received mine from unbeatable.co.uk and i was also led to believe it had prog scan!Was also bought believing it was region free and its not,have contacted them about both bot have to wait till monday for a response from tech dept.
  16. Phatboy
    Phatboy
    Sep 13, 2002
    85
    9
    Cardiff
    Check out the threads on the Limit 9900SE,PAL & NTSC prog, uses same chip as £1,000+ DVD players. Ive got one and it does it all ! simply amazing for £200!
