6500k Lamp
Discussion in 'Plasma TVs Forum' started by tbrar, Sep 22, 2003.
  1. tbrar
    tbrar
    May 31, 2003
    609
    16
    Has there been any update on the availability of an 'Ideal Lume' UK version of a 6500K lamp, or indeed any other simalar sources
    The topic was posted a while ago, but dont think it had reached any sort of conclusion, though I think waiting for the Ideal Lume version was recommended.
    Any suggestions ?? :confused: ..
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  3. Timmy B
    Timmy B
    Can we not just use a transformer?
  4. EvilMudge
    EvilMudge
    Does that mean that the D in D65 stands for Decepticon?:clown:
    Yes, but then it won't be CE approved, and in the event of a fire, even if not started by the lamp, your insurance wont pay out.
  5. Timmy B
    Timmy B
    If you build it, they will come.
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    It seems the take up in the dometic world in US has been really low. They sell them to telecine facilities a plenty but that's not enough to warrant trying to do a UK one.
    I'll speak with some folk and see if we can come up with something. It's not just a D65 lamp we want one with the right spectral characteristics, I believe
    Gordon
  7. EvilMudge
    EvilMudge
    Not entirely sure of the ground I stand on, but it was my impression that the 65 in the D65 indicates a colour temperature of 6500 Kelvin, and the D indicates the particular spectral characterisitcs (in this case I think it's fairly close to the natural/black-body spectrum). Therefore any D65 lamp has the right spectra. I know it's possible to buy other lamps which have different spectra at the same colour temperature point though.
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    The D is for the co-ordinates on the CIE chart. It happens to be 6504K. It is possible to get many devices to track close to or on D65. I do not believe that means they all have the same spectral character. If I get the chance I'll confirm this by showing you spectral chart of a DLP and a plasma both a D65. Should be interesting whether I am right or not.
    You are correct that spectra may not be the same at the same temperature.
    Gordon
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    OK brain is hurting. I'm actually a bit knackered and in cloud cuckoo land. Mudgy you are probably correct now I consider this with a beer in my hand....mmm..beer.
    Answers soon...on a postcard..
    G
  10. tbrar
    tbrar
    May 31, 2003
    609
    16
    So can I buy one or not :D :confused:
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  12. NicolasB
    NicolasB
    Oct 3, 2002
    6,506
    Emily's Shop
    +916
    Buy a light box designed to treat SAD, with daylight-spectrum bulbs....
  13. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    The last time this came up someone was going to try and get a Gretag Macbeth colour matching tube. Haven't heard anything since so did it happen?
    Would my front projector benefit from a bias light?
  14. EvilMudge
    EvilMudge
    I've got one, and it sits behind my centre.:D Actually it's a SAD alarm clock, and it has a positive effect on subjective contrast, but it's nowhere near being a correct D65 lamp.
  15. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Joe was looking into alternatives to the Ideal lume,not sure how he's getting on,maybe Joe you could post an update,there seems to be a reasonable amount of interest,I've been after one for ages with no joy.
    Rob
  16. NicolasB
    NicolasB
    Oct 3, 2002
    6,506
    Emily's Shop
    +916
    Not the same thing at all.
    I meant one of the "Zeus" boxes from here.
    Granted it probably still isn't 6500K. :)
    But even the standard bulbs produce a very nice, bright, white light that is much more energising and pleasing to the eye than what you'd get from a tungsten filament (even a halogen bulb). They also do "special daylight spectrum tubes" which, one assumes, mimic sunlight fairly accurately....
  17. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    The daylight spectrum is the sort of thing we probably need. I'm going to call Osram tomorrow and chat with their technical guys.
    Gordon
  18. EvilMudge
    EvilMudge
    I've got several filtered fluorescent tubes for standard fittings - these are specially designed to provide a daylight like spectrum, but they are incredibly bright. If you put one near a Plasma or LCD display you would need to shield the screen somehow, they would almost certainly 'wash it out'.
  19. NicolasB
    NicolasB
    Oct 3, 2002
    6,506
    Emily's Shop
    +916
    Put it farther away...? :)
    Incidentally, the Innovations catalogue used to sell tungsten filament light-bulbs that were supposed to produce daylight spectrum. The glass of the bulb was blue, owing to doping with some rare-earth element (I don't think they said which). I don't know if one can still buy these.
  20. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Innovations are down the tubes. In any case, with themit was probably a Sainsbury's pearl 100w with some blue nail varnish...
  21. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    That might have been me, but in their reply they stated that they are only sold in boxes of 10, so I didn't bother.
    No you don't need a bias light with a front projector since the display takes up such a large part of your field of view. The reason for a bias light is that a regular displays will take up a small part of your field of view, but will be very bright. That means that in a unlit room, your pupils will dilate since almost all your field of view is dark, but right in the centre is this small bright area. This conflict is very wearing on the eyes and causes fatigue. A bias light behind the display will increase the lit area that your eyes are looking at, without causing any distracting reflections on the screen. The need for a D65 bias light is so that the light itself is neutral and will not alter your perception of the colours in the display. It assumes that your walls, ceiling and carpet are all D65 in colour too. They are aren't they?:D
