6230i mmc card
Discussion in 'Mobile Phones Forum' started by gazza1988, Sep 23, 2005.
  1. gazza1988
    gazza1988
    hello i have just bought a brand new nokia 6230i, i would like a mmc card to put in this phone but my nokia manual says that im not to go over 512MB which other mmc cards are compatible with this
    my uncle owns a computer shop and has said that he is not sure if a regular mmc card would be adequate for my phone. but nokia branded ones are a bit steep in price. im not after the best deal i just want to know which card is the better one to choose?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    Any mmc card should work OK
  3. gazza1988
    gazza1988
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,055
    2
    4
    137
    Garstang, Lancs
    +1,596
    That's MMC+, don't know the difference, a normal MMC card should be fine.
  5. djidave
    djidave
    I got a 1Gb MMC card for my PDA and tried to put it in my Nokia 6230, basically it was too thick to fit in the slot under the battery. After comparing the 32Mb from the phone and the 1Gb one it seemed the 1Gb is twice the thickness.
    Also it had an extra contact on the corner where the slant is \_______|.
    Just 2 things to watch out for
    Dave R
  6. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,437
    Reading
    +170
    You are describing an SD card. Are you sure you ordered the correct item or that your supplier has not supplied an incorrect item?
