60hrtz ntsc or pal?
Discussion in 'Nintendo Forums' started by 7 of 9, Sep 29, 2004.
  1. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    if games is available in 60hrtz mode and i play it in this does this mean i am playing it in ntsc or pal still.
    thanks.
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
  3. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Xbox/GC/Dreamcast use PAL60 but the PS2 uses NTSC instead of PAL60
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,312
    PAL is the color encoding system and does a better job of it. PAL is usually used alongside a 50hz refresh rate but as the name suggests, PAL60 is PAL color with a 60hz scan rate (and the same number of lines on screen as NTSC).
    NTSC is also 60hz, but uses NTSC color and doesn't always look as good.
    Use an RGB SCART cable and you will get RGB50 or RGB60 (RGB is better than both PAL and NTSC).
