606 sync issues
Discussion in 'AV Receivers & Amplifiers' started by KingBaka, May 30, 2008.
  1. KingBaka
    KingBaka
    Jan 15, 2005
    924
    28
    +53
    Has anybody had any sync issues with the SR606?
    If i am using th PC OR SKy i alwasy get synic issues. I have tried the av sync opion but it is still way out.
    Do you think my amp is faulty
    Thanksin advance
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    22,173
    Poole
    +8,124
    What lipsync values have you tried? I found 40-50msec reasonable (but I would like 1 msec steps).
    Also did you make sure lipsync is enabled? This is a separate option.
