606 matches 875 for sound quality?
durk
ive not heard the 606 but the link you give doesnt say that the 606 matches the 875 for sound quality????????? I heard the 605 which uses pretty much the amp bits as the 606 its manly inputs and output and video scailing where they differ, and it didnt get close to the 875 in sound quality
james.miller
the 805 virtually matches it. its in a different league to the 705, which itself is a step up from the 605...which sounds identical to the 606.
so no, lol. anyway, the 606 is identical in layout to the 605 inside. the 805 and above are completely different.
http://www.avland.co.uk/onkyo/txsr606/txsr606.htm
http://www.avland.co.uk/onkyo/txsr805/txsr805.htm
http://www.avland.co.uk/onkyo/txnr905/txnr905.htm
take a look at the insides. the 805 (and 875) are built on the same design as the nr905 (the nr 905 has separate. transformers for circuitry though) the 605/606 are totally different.
nbat58
It doesen't say exactly that it matches it for sound quality, but more or less suggest that they are quiet similar apart from the differences they mention.
I do not beleive that any how.
Anything in regards to the 876 or are Onkyo keeping their lips shut for the time being so that they won't loose sale on the current models?
It really doesn't say they are similiar at all...the forum members are taking the **** :rolleyes:
