60" plasmas?
C
candiru
Hi, I'm looking to buy a 60" plasma with 1080i or 1080p resolution. Any suggestions?
Cyril
For 10k you can get the 71" LG, 7.5k gets you the Fujitsu 63", and you can get the Panasonic 65" for 7k ish or a Samsung 63 for 4.5k.
I would recommend the Fujitsu out of those first, with the Panasonic PF9 next, followed by the Pioneer.
onewingedangel
In all seriousness you could get a Sony SXRD pearl projector AND a 50" 1080p plasma for the cost of a 60" 1080p plasma - not a difficult choice in my books.
Cyril
If you can afford a 60" plasma, you can probably afford a nice projector as well :)
You may as well buy the panel versions as you can probably afford or already have a nice 7.1 surround system as well as nicer speakers than the ones built-in.
