6"x9"/8"three way/components?
Discussion in 'Video Streaming Boxes & Services' started by James45, Jan 15, 2003.
  1. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    I might as well get this started.
    looking to replace the speakers in the rear, made by me, parcel shelf. I've currently got a pair of ancient Pioneer 8" three way speakers and am looking to upgrade. do 6x9s give a different sound to their circular cousins? and would seperate tweeters and mids (something like the Boston Acoustics ccomponent) be a better option quality wise.
    running the speakers from the headunit (sony cdx-m670), no external amps involved at the moment although that may be the next step.
  2. d_devani
    d_devani
    well i got a pioneer cd head unit running some kenwood 6*9 on a rectangular wood thats mounted under the parcel shelf, all this carpeted as well, and it kicks, there is no need for a amp.
    But I am told sound can vary depending on the boot shape.
    so hers a new vw polo, I've also heard 6*9 in a mk2 golf and they kick.
    I had a calibra and the acoustics were crap.
    Personally I'd go for 8*10 speakers Kenwood do them.
  3. d_devani
    d_devani
    sorry i didnt answer ur question
    The only main advantage of components is that u can place the mid/tweeter at different hights, u cannot do this with 6*9's
  4. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    The 6x9s I have in my present car ( Selling next week) were a disapointment. They are nothing amazing, some Sony Explode, the modle number escapes me. The midrange is excellent, just no base or depth to the sound. And if you up the base setting on the head unit it just becomes all wolly, and make that horrible bor racer noice best described as WOB WOB WOB :D
    Any ideas on the best way to get tight punchy base?
    Paul
  5. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Buy a decent sub and an amp.
    Kicker subs are buy far the best car audio subs on the market IMO, team this up with a rockford fosgate amp and hey presto, nic tight punchy bass. Rockford fosgate pride themselves on the quality of there amps and to be honest I can see why they are perfect in nearly every way.
    6x9's are meant as a midway between midrange speakers and subs, they give a little more kick in the bass than a mid, without compromising vocal clarity.
    As far as mounting them is concerned, buy a stealth shelf, for about £50 you get a wooden shelf, that is covered so the speakers cannot be seen, but it also has holes precut so you can mount the speakers in the shelf.
  6. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Where can you get a stelth shelf from?
    Paul
  7. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
  8. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    My advice, don't put speakers in the rear.Concentrate on the front, consider a set of comps and amp them and a 10'' or 12'' sub for the boot.
  9. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
    The Pioneer 8" speakers have always been excellent with regards to bass and you may be dissapointed with alot of 6X9's.
    The theory is that an oval 6x9's gives approx. the same amount of bass as an 8" speaker, in my opinion this is not the case I've always prefered 8" speakers.
    The advise about concentrating on the front end is correct, these are the most important speakers in the car then follow it up with a single sub this will give the best system for quality and imaging.
    Kicker subs I have found to good for dance type music but JL are far more musical and still do an excellent job on dance.
    In todays market the norm is to fill the car with as many speakers and amps as possible, some of the best systems I've built or heard have only had components in the front and single 10" in the rear.
    Oblivion, check the phasing on you speakers the Sony's are not fantastic for quality but do give a resonable amount of bass.
  10. James45
    James45
    Sep 21, 2002
    2,844
    59
    I have infinity kappa 4" components up front, but the mounting location in the renault dash is hideously flimsy and the grill doesn't allow for any midrange cone movement, so short of building door pods for some Bostons (which are by the way the best component car speakers I have ever heard) I am relying on the back shelf for bass. sub in the boot ain't really an option as I use the boot a lot.
    as for shelves build your own, it couldn't be any simpler. just use your existing parcel shelf as a template to cut out some MDF, don't use anything thinner than 18mm (i used 15mm on my latest one and the bass is horribly boomy and uncontrolled. then cover with some acoustic cloth (from car audio dealers) using spray on glue (one of the messiest things ever invented).
    Cutting out some MDF spacers for underneath maybe neccessary as well if the midrange and tweeter unit of the 6x9s is not flush with the level of the shelf.
  11. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
    What Renault is it?
  12. James45
    James45
    Sep 21, 2002
    2,844
    59
    clio phase 2, in dash 4" mounts with a nasty plastic grill that the cone will touch if played loud enough, i need to build some sort of solid spacer to push the speaker further back into the dash and away from the grill. some dynamat is also needed in the dash to deaden it a bit.
  13. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    Got one of those vibe 10" sub with Amp and it really rocks. All I did is just check the low frequency cut off of the 6x9 (sony xs5693) and the Pioneer 6x8. I think it was 30 then I set my sub crossover to 50 (i never believe car speaker ratings) and hey presto really good sound.
  14. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
    Unfortunatley I'm off work at the moment so I cannot verify this but I 'm sure that you can get a 6" speaker in the doors of the Clio. You will need to remove the door panel to check for mounting depth and clearence from the window.
  15. James45
    James45
    Sep 21, 2002
    2,844
    59
    I wish... there are no grills in the door panel and it would involve cutting, which I won't be doing.
    having said that I was listening to Massive Attack on the drive in this morning and it sounded fantastic, so I think I will build a new shelf out of thicker MDF to sort out the bass, work on some spacers to push the infinity drivers away from the grill and sort out the acoustics of the dashboard.
  16. craigizmo2k2
    craigizmo2k2
    In our peugot 309 in the rear parcel shelf we have a pair of 6x9s powered by a pro plus amp (was installed for free when my uncle owned the car) and i was thinking of getting a sub for it (though dad wont let me buy car audio as im 13 he'd end up having to fit it!) there was hardly any bass at al, shounded rubbish. and i found a switch for a subwoofer, turned the gain down to a quater and flicked the switch, hey presto, punchy, nearly seat shaking bass at the cost of flicking a switch!
  17. Dave20
    Dave20
    componants in the back = waste of time, unless you spending like £300+ on them and another £300+ on an amp to run them. though i and most car audiophiles never have speakers in the back.. only in the front. the back is for bass only. 6x9's are a good fix for needing base.. 8" 3ways need to much power to sound bassy
  18. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Is it this model ?
    Link
  19. James45
    James45
    Sep 21, 2002
    2,844
    59
    tis indeed but I was talking about the fronts... those speaker placements in the rear are empty.
  20. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    This must be them then Link
