technotyke
- Joined
- Apr 7, 2010
- Messages
- 53
- Reaction score
- 0
- Points
- 30
Im just looking for opinions and any good/bad experiences if anyone can help it would be much appreciated
Im currently looking for some 6 way sockets. I have some new tv/video/audio equipment and id like to make sure its as protected as possible and I also need plenty of sockets to plug them into
Just wondered if anyone has a preference for a surge protected socket? Is surge protection worth it? Do any have guarantees and are they worth the paper they are written on?
Any thoughts on the best ones out there? I am probably in need of half a dozen for my flat as all the others are getting pretty old now (ie green light for surge protection no longer switches on).
Do I need to spend a fortune or should I be fine with the cheaper models
