6 speaker mishap
Discussion in 'Home Cinema Speakers' started by Sam41, Jul 31, 2004.
  1. Sam41
    Sam41
    :thumbsup: Good day
    Right I have a new 5.1 speaker system, and all I want to do for now, is to play my ipod through it. My system takes input via phono (red and white, yeah?) leads and requires 6 leads to be connected for sound to be played from all of the speakers, but my ipod cable only has two phono plugs. So I can only listen to the sound via two speakers. Basically, is there a splitter or something to split the sound from a 3.5mm jack output to 6 phono plugs or something similar.
    Yes, i'm new to this stuff, so some terms may be sketchy. anyway, i anticipate ay help given
    thanks
  2. Sam41
    Sam41
    sorry, but i would also appreciate any info regarding connecting my xbox to the system, as the xbox supports 5.1, but my speakers have no optical in/output (I am unsure whether this is required)
    Thanks again
  3. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    Simple fact is that the ipod doesn't produce surround sound.
    You can however get a wrap around stereo effect going by using 'Y' adaptors on the phono's of the ipod at least this way you can use 4 speakers.
    But what you really need is an AV amp or processor featuring Dolby ProLogic II, DTS Neo:6 etc. With this you simply plug your two stereo phono's into the amp and it splits the signal into a convincing surround experience rather than just have a stereo signal that is just blurted out over 4 speakers.
    EDIT: That may sound very confusing but the fact is I'm quite p*ssed at the moment and need sleep badly!
  4. fraggle
    fraggle
    Dec 11, 2002
    1,507
    Milton Keynes
    +57
    To add to Shiobis response you'll also need a digital optical input on the amp to accept the output from the X Box.
    I'm not aware of any amps that don't have optical inputs, but better to ask anyway :)
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK i am guessing your system requires a DVD player with onboard decoding, Creative do an external decoder which is what you need!
  6. Sam41
    Sam41
    Hi, thanks for the replies, they were very helpful.
    Does anybody have a link to this external decoder i've searched but couldnt find the creative one (and am unsure what i am after)?
    Thanks you again,
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  8. Sam41
    Sam41
    Thanks again dragon, I hope to order this asap.
  9. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
  10. Sam41
    Sam41
    Yeah cheers man, amazon seem to have it for just under £80 (exc postage etc though) but that isn't too bad. Are there any other good alternatives worth considering? Especially if it can save me a few quid, if not i'll shell out on the Creative DDTS100.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    amazon free P&P over £25 and, £3 off for first time user!
  12. Sam41
    Sam41
    Nice one! I didn't realise
