jonny round boy
Established Member
I've been looking at several options for new speakers to wall mount around my LCD tv, both seperates & all-in-one packages. Not being able to find exactly what I want (aesthetically), I'm thinking of going for the Tannoy EFX5.1 speaker set.
Trouble is, they're 6 ohm speakers, and my old Sherwood amp specifically states on the back 'use min 8 ohm speakers'. If I connect the EFX5.1's to it, will it damage the amp? If not, what other problems might it cause?
I also looked at the older FX5.1's (which are 8 ohm), but wanted the wider centre speaker.
As you have no doubt gathered, I'm a bit clueless on this kind of thing...
Thanks in advance.
Thanks in advance.
