6 channel Power Amp Advice
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Buckster, Sep 3, 2005.
  1. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Just a quick query really - I've a Pioneer 2011 which I think is absolutely superb - best sound steering I've heard - but sometimes find the amplification a bit lacking (quality wise - although all relative)
    Would a Power Amp upgrade to something like a Rotel RB985 be worthwhile - or would I not really notice a difference unless I went for a higher model ? Its hard to judge how the Power amp stage of the Pioneer would compare to something like the 985
    Thanks for any help
    Mark.
  2. skinnyfat
    skinnyfat
    The Rotel power amps are superior to the pioneer's, not only in 'real' power, but current delivery, construction, components, transformer, etc. etc. which will translate into better sound quality, stability etc etc. So in short, yes you will notice a difference
  3. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Ta - thanks very much Skinnyfat - its just you see the 985s going reasonbly cheap now (250 odd) - so seems a worthwhile not too expensive upgrade
    Mark.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Moving to processors and power amps.
  5. spiver
    spiver
    Dec 26, 2004
    1,131
    48
    +33
    Try the Rotel RMB1066 if you acn afford to spend a bit more (around £400-£450 second hand or £600 new) and don`t be put off by the conservative 6x60W. Its a lovely amp. :smashin:
    If you are looking for something cheaper the older Rotels are very good value for money.
