6 Channel Audio Inputs
Discussion in 'Cables & Switches' started by sapper, Jan 15, 2008.
  1. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    I have a problem that I would like to solve....
    If it is indeed possible, preferably cheaply...
    I currently have a superd Denon 2900 DVD player connected to my Denon Amp using Digital and 6 channel Audiio leads, for Movies and Multi Channel Music respectively
    I have also built a HTPC that will play both formats of HD discs. However currently I am using the SPDIF connection for the audio tracks.
    Because (apart from being too lazy to remove everything to make the connections) my 6 channel inputs are used by the DVD player I cannot connect the 6 channel Audio out leads to the Amp.
    What I need is a simple switching system that will allow me to pass both sources into the AV amp.
    Any ideas on how I could achive this?
    Preferably soemthign affordable (and green friendly)!
    Adrian
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    I haven't seen any audio switching units that accept 6ch audio and output 6ch audio, most are for stereo use only. I have no idea whether this would work, it would certainly be a cheap solution if it did! However, I don't know if there would be room for 6 of those in the back of your amp, you might need more cables to connect to them.
  3. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    I would imagine, inaddition to extra cables, female to female converters would be required? Alternatively something like this Phono 2 Sockets to 1 Plug Cable from maplins...
    What is the best way of accessing the 3.5 mm jacks on a motherboard to normal phono connectors?
    There seem to be a variety out on the market...
    Any suggestions most welcome
    Adrian
  4. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    Bump....
    What are the best leads - (or at least the best compromise re cost agasint audio quality) for taking the 6 channel sound from a HTPC soundcard (i.e a 3.5 mmm jack) to a phono connection.
    I will need 6 cables to connect my asus motherbazord to the 6 channel input of my AV amp.
    Any recomendations please??
    Adrian
  5. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
    What sound card do you have on your motherboard? It cant be complicted sometimes depending if you card is a 6.1 or 7.1. My sound card a x-fi xtrememusic (7.1) has 3 mini jack ports, it cant handle 7.1 but my setup is 6.1 so i have 1 jack for the fronts, 1 for the rears, and 1 for the front centre, rear centre and sub.
    The front and rear channels are fine, i use a mini jack (3 pole) to twin phono for these but for the centres and sub i had to use a 4 pole mini jack to triple phono lead to get the full 6.1
  6. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    I have an Asus AM2 motherbaord; asyet I have t invested in an additiqanlsound card, mainy due to insufficent slots within the HTPC!!
    I do beleive my 6 outputs(5.1) are mono (Single channe0 - but Guess I need to re-read the manual to confirm before I order anyhtitng.
    Just opened up the SoundMax drivers software...
    For a 5.1 System which is what I have,
    blue = line in
    green = Front out
    pink-red = microphone in
    white = nused
    black = Rear
    Orange-red = Centre & subwoofer..
    So I need three 3.5mm stereo to phono jacks.
    A good start on what exactly I need but still need recomendations plese
    Adrian
  7. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
  8. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I would normally suggest an optical connection as well, but in this case as the source is HD I'm guessing the PC is decoding the HD audio hence the need to use the analogue outputs?
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,606
    The Borders
    +3,496
  10. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    Iam currently using A digital SPDIF for DTS and DD but I may try and tinker with arcsofts new software.
    this will apparently decode true HD. As its still an experiment I do not want to invest too muich as yet
    Thanks for your replies peeps..
    Keep them comming :lease:
    Adrian
  11. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    Cheers Joe,
    Quite a box there, and as yousuggested not cheap...
    It looks very powerful, and if it could double up as a seperate HDMI swithcer then maybe not so an out ragious idea
    Adrian
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,606
    The Borders
    +3,496
    Hello sapper
    Zektor have the HDMI + 7.1 Multi Channel audio option covered - though its more expensive; see http://www.zektor.com/mas71/index.html
    The HDS4.1 is a brilliant bit of kit if you need to Switch Component Video or Multi Channel audio along with Optical and Coaxial audio - its integration features make it a breeze to set up and operate.
    Joe
