6 channel and co-axail can't tell difference?
Discussion in 'Cables & Switches' started by av addict, Oct 13, 2005.
  1. av addict
    av addict
    Jan 27, 2005
    2,218
    +179
    hi just bought some jvc 6 channel cable for dvd-audio but i can't tell the difference between co-axial-is this normal or are they just as good as each other.
  2. loadsofleads
    loadsofleads
    Does DVD Audio travel over coaxial :confused:
    I thought both multi-channel high resolution formats (SACD & DVD-Audio) had been specifically designed NOT to be used with either coaxial or optical. Although i link and other variants such as Denon link will carry them in their original format.
    Are you sure that the it isn't downsampling to Dolby when your using coaxial ?
    If your using 6 RCA cables to receive multi-channel sound in it's origianl format, have you set it to output this on your DVD-Audio player ?
  3. av addict
    av addict
    Jan 27, 2005
    2,218
    +179
    good question :suicide: i'll hav a look later cheers for that :suicide:
    i just persumed it was already active as it says 6 channel on my amp-but
    obversley need to activate it on my dvd player then
