6 Chanel switchbox how ???
Discussion in 'Home Cinema Building DIY' started by JSW, Jan 24, 2003.
  1. JSW
    JSW
    Feb 21, 2002
    4,239
    Staffs
    +321
    I need a 6 channel Switchbox so I can swith between SACD and DVD A.
    How would I go about making one ??
    Bry
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    High Wycombe, Bucks, UK
    +59
  3. JSW
    JSW
    Feb 21, 2002
    4,239
    Staffs
    +321
    Thanks ReTrO :)
  4. themadhippy
    themadhippy
    a 6 pole 2 way switch is the simplest solution,something like rs components part numbers 352-238 and 352-187
  5. catrevilla
    catrevilla
    Cat here,
    I don't know if in England or in your country there is RadioShack (a chain of stores that sells electronic components here in the US, Mexico, and other Latin American countries, I don't know if there is one in europe since I've never been there), but I know that in England there is the Maplin Electronic Store. They should have a switchbox for audio/video. You can buy it there.
    If you don't want that and you want some simple switches, then I can recommend you an old design that I have that uses TTLs, and analogic integrated circuits.
    If your interested, PM me or e-mail me so I can e-mail it to you. This circuit works well and is compatible with any video format (PAL/NTSC).
    Catrevilla
  6. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    How about a 2 (or more) way fully wired scart switcher. Then use a scart - 6 phonos for each in and the out.
    I know the quality of the scart cables won't be up to the highest quality Audio cable ... but would be worth a try ... could always later get some audio cable wired upto the scarts connectors.
    Victoria
