6.1
Discussion in 'AV Receivers & Amplifiers' started by sapkan, Dec 25, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    Can all modern 7.1 receivers work simply in 6.1?
  2. recruit
    recruit
    Sapkan - Yes they will only decode 6.1 (DD-EX or DTS ES)as there is not a format that supports 7.1 yet even though amps are quoted to have 7.1 it splits the signal for the 6.1 and feeds it thru the 2 rear speakers in mono.
    If you are just wanting to connect a rear centre then you can and usually one of the speaker outputs for the back rears will be labelled up to take priority for the 1 speaker..
    John
  3. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    makes sense now, thank you John
