6.1
Discussion in 'AV Receivers & Amplifiers' started by parkem50, May 20, 2004.
  1. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    Hi, just been given a new HK avr630 from the future wife!
    Sounds superb! Only problem is how to wire up for 6.1
    I have a spare matching center speaker which would be ideal for a rear center. The amp has speaker outs for 7.1 ie two rear surrounds. Is it possible to wire up one speaker in stead of two?
  2. Anth-M
    Anth-M
    You should only need to connect your rear centre speaker to one of the connectors, also you will need to change some setting in the menus, the manual should tell you how to do all this.
    Anthony
  3. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    Thanks for the reply.
    Cant see anything in the manual, but i will have a play, then pull up the carpets and lay more cables!
