6.1? Watt the hell is that?
Discussion in 'AV Receivers & Amplifiers' started by rich tee, Sep 19, 2003.
  1. rich tee
    rich tee
    May 30, 2003
    415
    Bristol
    +7
    I'm looking to buy a new amp to replace my Kenwood KRV5030.
    I've read about 6.1 amps. how do they work as opposed to 5.1?
    do you need a 6.1 DVD player? if not what would the connections and set up be?
    Any answers much appreciated.
    Rich Tee.
    rolleyes:Tosh 32zp18q tv
    Tosh SD 520e dvd
    paradigm pdr 10 sub
    Jpw minims
    Gale 10 centre:confused:
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    It just adds a central rear speaker..... i think if your player does dd/dts..... it will also deal with the 6.1 version ok. But...... dont forget 7.1 as well....
    Ad
  3. rich tee
    rich tee
    May 30, 2003
    415
    Bristol
    +7
    Cheers Buns.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    AFAIK there are no 6.1 (or 7.1) DVD players. To get 6.1/7.1 you need to connect the DVD player to the amp/receiver by a digital coax or optical lead. The amp then does all the decoding and can create a surround rear signal from a 5.1 encoded disk.
    You can now buy Dolby Digital EX or DTS ES disks which are 6.1.
    On a 7.1 setup the 2 surround rear speakers are mono.
    Mark.
  5. rich tee
    rich tee
    May 30, 2003
    415
    Bristol
    +7
    Thaks MarkE19
    Great advice.
    regards
    Rich tee.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Note there is no such format as 7.1, max. at this time is 6.1 (DTS Es Discrete) though MPEG-MC was specified as one. DTS is btw not limited to 6.1, so it could in future become 7.1 or even more.
    Thus 7.1 usually refers to the amount of speakers in your system, where usually the surround back channel of a 6.1 format is split and amplified seperately (the signal remains mono of course).
  7. sdh500
    sdh500
    Yes, good point. Some Yamahas (e.g. DSP-AZ2) are even specced as 8.2 :eek: , though in reality this turns out to be 6.2, i.e. with only one central rear, plus 2 extra front (effects) speakers and an extra sub. Still, the 8ch Stereo mode is fantastic!! :clap:
