6.1 or 7.1
Discussion in 'Home Cinema Speakers' started by philthyanimal, Jan 12, 2004.
  1. philthyanimal
    philthyanimal
    I have an AX3 and i am adding extra speakers to my 5.1 setup.
    Which should i do, 2 extra rears or 1 rear centre?
    My system doesn't have PLIIx so are 7 speakers going to work? will sound come from both the rear back speakers?
  2. eyerish
    eyerish
    You should definetly use 7.1 It gives a much more convincing and better placed soundfield to the rear, if set up properly. The idea is that with only one spkr at the rear, the mind plays tricks and at times effects sound as though they are coming from the front and not the back. So 2 spkrs are used to place a stereo image behind you. Doesn`t matter if you have PLIIx or not. This is only a form of enhancement for Pro Logic II.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    The surround back speakers in a 7.1 setup are mono - they both output exactly the same signal. It just gives a wider, less directional sound with 2 speakers. Although my receiver can drive 7.1, I only have 6.1 due to lack of space and think the results are still very good.
    If you have the space and money then go for 7.1, but if not then 6.1 still works very well.
    Mark.
  4. philthyanimal
    philthyanimal
    how far behind should the rear back speakers be, also how close together. Do they have to be the same height as the rear surrounds?
    Any help most welcome
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    I think it is recommended that the rears should be at least a metre behind you and close together, ie not on either side of the rear wall.
    Mark.
