6.1 Full Size Speaker Package - £750 budget?
Discussion in 'Home Cinema Speakers' started by steve 111, Sep 15, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    The wife has finally relented that I can now have a full size speaker package to replace my Kef 2005.1 set up. I also want to take this opportunity to go 6.1 and the speakers are being paired up with a Yamaha RXV650 Amp.
    My budget isn't huge c.£750. What would you recommend based on my budget and the amp they're going to be used with?
  2. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    Acoustic Energy Evo's spring to mind, but if you can stretch your budget by another £250, you could go for the Mordaunt Short THX Select speaker package for a bargain £999!!! Richer Sounds are currently selling the package at that astonishing price.
    I think Monitor Audio also do a package to fit your budget?
    Mordaunt Short also do an Avant full size speaker package too for about £800
