6.1 bipolar setup?
Discussion in 'Home Cinema Speakers' started by sk4nky, Sep 8, 2004.
  1. sk4nky
    sk4nky
    Aug 30, 2004
    138
    now, wharfedale recommend that their DFS18 bipolars are to be mounted on the back wall facing towards the front when its a 5.1 setup.
    anyone had any experiences using bipolars in a 6.1 setup? as in using bipolars for all 3 surround channels?
    thanks.
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    That's what I'm currently using, but with 4 Eltax HT2s. They work very well - I originaly had 4 Acoustic Energy Aegis 1s as the side and rear surrounds, but found the rears were causing imaging problems. I tried angling them down, but although the problem was reduced, it was still there. The Bipoles cured the imaging problem totaly, but still give a very clear and precise rear sound field.
    I then swapped the side A1s for another pair of HT2s because there's very little sound difference between them - Bi-poles are just a pair of monopoles in a single box as far as I can tell, so the point source which is technicaly the 'accurate' way to reproduce the audio is still there.
    You still get accurate imaging despite the wider dispersion field - you can easily tell which speaker sounds are coming from, and in my room, there's very little difference between the bi-poles and mono-poles.
    HTH
    Gary.
  3. sk4nky
    sk4nky
    Aug 30, 2004
    138
    so you have your eltax SL/SR on the wall to your side (or slightly infront of your listening position) and both SB on the back wall?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Just about the same sort of setup as me. 2* Biploars inf ront of the listening position and 2 in the rear. :smashin:
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    Yes - two either side of the listening position about 10ft apart, and two on the rear wall 4ft apart (the rear wall is approx 5ft behind the listening position).
    Gary.
