6.1 advice.
Discussion in 'Home Cinema Speakers' started by Les E, Dec 8, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    949
    St. Helens
    +18
    I currently have the KEF eggs set-up as a 5.1 system, but I will be setting up a dedicated room next year and I am thinking of expanding to 6.1 as my amp has the facility.
    However I have had different advice of how to set-up the 6.1 and whether to use 1 or 2 additional speaker(s) for the centre rear.
    Has anyone got a definate answer to this? Will there be enough information for 2 mid-rear speakers?
    My room won't be that big (11ft by 8ft) plus there will be a door to the rear left of the room.
    Any thoughts anyone?
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    In an ideal world, 2 additional rear speakers would be best. But depending on your room setup even an additional rear would make a difference. It all depends on how much room you have!
    I know my better half wouldn't let me have 2 additional boxes in the room :laugh:
  3. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    Since there are no 7.1 (REAL) sources (and very very few 6.1), one additional center rear will do the trick!
    It's only when the room layout is very wide that 2 center rears might (just might) make sense!
  4. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    Im nust setting up a 6.1 with one rear now, will let you know what sounds like tomorrow hopefully if amp arrives. should have been here today but waited in all day and wasted my time, dont you just love slack companys who cant keep to what they say when they take money off you
  5. Les E
    Les E
    Oct 5, 2004
    949
    St. Helens
    +18
    Thanks for the advice...I had a feeling 2 centre rears was a bit extreme but just wanted to check it out with you guys.
    I look forward to hearing your opinion when you're set-up Gooner. And no, you can't trust the buggers to deliver on time...I waited in for 3 deliveries of the same TV and they tell you it's not in stock on the morning you've taken the whole day for!!! I ended picking the TV up myself! :suicide:
