6.1 7.1 speakers
Discussion in 'Home Cinema Speakers' started by Tobez, Mar 14, 2003.
  1. Tobez
    Tobez
    Before i start i know that 7.1 isnt a standard, but i have the option to have it and the wires are there so i need to fill the slots.
    Can ne1 advise me of any speakers that arnt boxes examples Mission FS2, that would work as my back pair, The missions rely on there active sub and thats only capable of 5.1, so i cant really add 2 more, i need speakers that work from my PIONEER 2011 and offer all the ranges i need but dont look stupid and can blend in to the room ISH and also dont require me to chisel a hole out :)
    thanks
    my budget isnt bit so 300 ish would be good
    Tobez:hiya:
